01-11-2007 11:04 AM
01-11-2007 12:14 PM - edited 01-11-2007 12:14 PM
As long as the data has a LF at the end, something like the code below should work. The VISA Configure Serial Port has a enable termination input and the default termination character is a LF. That means that the VISA Read will automatically terminate whenever it sees this character. You can specify some large number of bytes to read and it will just read the actual number of bytes up to the termination character. If there is not so much data that it takes more than 500 msecs to read, the Wait Until Next ms Multiple should keep up with the instrument. If you are doing a lot of processing in the read loop, you might want to move it out so that the read does not fall behind.
Message Edited by Dennis Knutson on 01-11-2007 11:15 AM
01-11-2007 01:24 PM
01-11-2007 01:38 PM
01-11-2007 03:04 PM
01-11-2007 03:33 PM
01-11-2007 07:01 PM
01-23-2007 01:27 PM
01-23-2007 02:16 PM
01-23-2007 05:04 PM
The documentation on the instrument says that is transmits every half second, but I found out after I got my program working that it is actually close to 4 Hz; I even checked to make sure that I'm getting a unique reading every quarter second. I don't know why it is only in multiples of 16 ms and I can't change the frequency that the instrument automatically transmits data. I posted a jpg of that part of the program, is there something there that is messing stuff up?
Spencer
