Reading irregular string from a file
Dear All,
I have an original txt file named scal.txt. It's irregular string. I used excel to save as with tab format named scal-1.txt. It can read from LabVIEW. How can I read irregular string with in LabVIEW. Thank you.
(4,286 Views)
Your original format uses fixed width. So you need to split each line at the nth position.
Felix
(4,274 Views)
Dear F. Schubert,
Which function can I use. Any examples? Thank you!
(4,270 Views)
Accepted by topic author Ancle
This is quite simple. Use help for more information.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,258 Views)
In the string palette you might find a lot of useful functions for manipulating strings. I'm not sure with the names (I memorized the icons), but I think one was called 'Pick line' and the other was called 'split string'.
Felix
(4,237 Views)
On a side note, things would have been quite a bit simpler with this idea implemented. Please support it if you like it! 🙂
(In this special case of fixed width fields, even this idea would have solved it. ;))
(4,202 Views)
