I'm trying to use LabVIEW to read an analog voltage from a DPM-3. It has a 10 Vdc range with 5 Vdc being it zero with 5-10 Vdc being the tension reading and 0-5 being the compression reading. My problem is when trying to read the tension side, it only goes up to 5.23 Vdc on my numeric indicator. I don't have any problems reading the compression side. I am using a NI USB-6009 to read my voltages. Is there a limit somewhere in the 6009 somewhere or did I not set something up correctly in my data acquisition? Thanks.
