Reading matlab matrix to array
I am using a Labview programme to control a UAV. I didn't write the code and have no experience of Labview (so pardon my ignorance :)). I have a set of waypoints in a .mat file that I would like to be an array input. At the moment, the array is a control from the front panel to type in the waypoints but I have too many to type in each time.
I thought that using a .csv file would work and tthen read from spreadsheet but I can't get it to work.
Any suggestions appreciated.
(3,288 Views)
Hi buzz,
- a *.mat file is no *.csv file.
- in your picture there is no ReadFromSpreadsheetFile shown
- you work with an array of cluster elements
Use a CSV file with your waypoints. Read that file using ReadFromSpreadsheetFile. Convert the 2D array you receive to your array of cluster…
(3,275 Views)
