Reading measurement file correctly
Hi Seessami,
i think the write vi works as expected, but the read vi not. You can connect the header cluster directly as data type input to the "read from binary file".
Hope it helps.
Mike
Message 11 of 17
(864 Views)
Yes I can do that but it doesn't change anything. If I understand correctly, you mean to put the cluster constant as an input to the "read from binary file"?
Message 12 of 17
(851 Views)
Hi Seessami,
yes, that´s what i mean. If i do it, i can read the file created with the write.vi.
Mike
Message 13 of 17
(848 Views)
Hi Mike,
Could you send me the changes you made in the vi. I'm not getting this work for some reason..
Message 14 of 17
(843 Views)
Hi Mike,
Here's my E-mail:  samir.khiat@orbis.eu
Message 15 of 17
(806 Views)
Hi Seessami,
see the attached example. I changed your read vi. Use the State machine architecture to insert the rest of your code into this structure. Smiley Wink
Hope it helps.
Mike
Message 16 of 17
(794 Views)
Thanks Mike!
Message 17 of 17
(788 Views)
