Reading multi line text and count the lines
Hi need help let say i have multi line text and i need to count how many lines in the text.
Example this is the text.
"REC UNREAD","+60126422014",,"08/05/13,14:37:40+32"
**AC ok**
SED001 TESTING 14:33 13/05/08
12.12 VOLT
DR1=OP,DR2=OP,MTD=OFF,RSP1=REP,RSP2=REP,RSP3=REP,SA1=REP,SA2=REP,SA3=REP,RAS1=REP,RAS2=REP,
some text many be more than 5 line.
Plz help.
Message 1 of 8
(3,493 Views)
Hi jeyanthi,
you can for example use the search and replace function. Search for the line feed sign "\n". If you use LabView 8.x then you get a number how many signs are replaced. I´m not sure about the exactly version number.
Mike
Message 2 of 8
(3,486 Views)
Hi jeyanthi,
see the attached example picture. The constant connect to the search and replace inputs is in "code display".
Mike
Message Edited by MikeS81 on 05-16-2008 08:00 AM
Message 3 of 8
(3,477 Views)
thnk u very much.Smiley Happy
Message 4 of 8
(3,470 Views)
hi need help .. how to remove the first line only..line(0)
i just need line (1) and above
how can it been done
Message 5 of 8
(3,399 Views)
Hi jeyanthi,
you can use the "Match Pattern" function. Search for "\n (Code Display)" and use only the string after match. Another solution is to create an array of it and remove the first line. Use the function depending on how you have the data. Smiley Happy
Mike
Message 6 of 8
(3,393 Views)
To see other ways to count lines you can see this response.
Message 7 of 8
(3,381 Views)
Thank you smercurio for attaching a wonderful link. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 8
(3,349 Views)
