Reading multiple channels in one task
Hi i am trying to read three voltage inputs in one task. I have configured the task and used generate code to get the example. But i am now getting the data from all three channels in one waveform, but i would like to work independantly on the three channels. What should i do.
(3,000 Views)
Hi vamy,
If you read all channels with AI Read, it should return an array of waveforms (not just a single waveform). You can use "Index Array" to get the waveform from each individual channel, or use "Index Waveform Array", which is basically the same operation.
Dan
(3,000 Views)
Hello Varny,
Yes. As Dan has mentioned, you can use the Index Array function to seperate out each individual waveform channel.
Bill B
(3,000 Views)
