Reading shared variable value on client VI
Hi, I have a server VI created and shared variables created and deployed etc. When I create a client VI should i not be able to drop the shared variable of an indicator onto the new block diagram and see the value from the server VI on this.
Kind Regards.
(2,817 Views)
If you're using a Server VI to create and launch your Shared Variables, then you probably want your Client VI to connect to those variables programmatically.
Have a look at the links below for some info.
Reading and Writing Shared Variables Programmatically
Using the LabVIEW Shared Variable
Patrick Allen: FunctionalityUnlimited.ca
(2,792 Views)
