Reading simple data from HTML and transmitting to LabVIEW front panel
Hey guys,
I have a simple VI where I write random variables to a HTML chart and display them through a web browser. But I want to create a very simple button (Like a boolean) on the HTML page and when I click it I want LabVIEW to read that data and turn on an LED on the LabVIEW main vi.
I have researched to no avail - I was wondering if I could get a hand? Here is my current set up. This was mostly followed through with a Bloomy tutorial.
Any help would be amazing - Thanks!
(3,272 Views)
Hi Muri777,
Are you having trouble with creating the button, or reading the HTML data?
Reading the HTML can be accomplished in LabVIEW, but creating a button to run a VI sounds more like a PHP or JavaScript question.
Alternatively, you could publish your front panel to a website, and handle the whole task in LabVIEW.
There may be other methods out there as well, but this is what I've found so far. Hope it helps!
Travis N.
Applications Engineering
(3,215 Views)
