Reading unsteady mass from Mettler Toledo XS6002s balance
I have connected a Mettler Toledo XS6002s balance to labview using the driver on the NI website. It works but it only reports the steady mass readings. Is there a way to collect the unsteady readings from the balance using labview?
(3,024 Views)
I believe that in general Mettler Toledo uses a protocol called MT_SICS. The command for instantaneous readings not just stable ones is SIU (concatenate with a carriage return and line feed constant) and you should receive instantaneous readings.
Hope this helps..
(3,010 Views)
