Reading values from a Matrix
Hello everyone,
i have a big VI with a big while in it, which generats at the End an Array (Attatched). I want to read the Values (continually) from the Matrix, what i am getting now is only the last Value 😞 For example: i want for X to read: 0, and then 250, then 0, then 250. BUT i am only getting the 250 at the End). Can anyone helps me how to split the values from the array and then read the vlaues from each coulomn one for one?
Thanks a lot!!
Message 1 of 18
(3,873 Views)
Hi Ayman,
As long as you don't attach your VI we cannot tell you where you went wrong…
Attach (a simplified version of) your VI which shows the problem you have right now!
Please don't mix the terms "array" and "matrix", these are two different things in LabVIEW…
Message 2 of 18
(3,869 Views)
Thanks for your reply.
i made a really simplified version to show what i mean.
So what i need is: to seperate the x coloumn from the y coulomn and read each line from the column step by step. That means: i would like to read in an indicator the first value of x then the second one....etc. and the same for y.
Message 3 of 18
(3,863 Views)
Hi Ayman,
When you need to read two columns in a 2D array you should use IndexArray…
Use an autoindexing loop on your "X column" array…
Both is pretty basic LabVIEW stuff: did you take care of those training resources offered at the top of the LabVIEW board?
Message 4 of 18
(3,851 Views)
Thanks again for your reply.
of course i tried autoindexing. But my problem is: i need to feed these numbers to a motor control in x direction, and i want to give the motor the values in x step by step. if i use Autoindexing it would allow me to have a scalar only inside the for loop. I tried to wire the input of the motor insid the for loop where i am getting the values of the x column and i keep getting: The type of the source is long [32-bit integer (-2147483648 to 2147483647)].
The type of the sink is 1D array of
double [64-bit real (~15 digit precision)].
Message 5 of 18
(3,842 Views)
I would be really thankful for any help 🙂
Message 6 of 18
(3,829 Views)
Hi Ayman,
Again you forgot to attach the VI. How should we debug your VIs when you always forget to present them???
See this:
These are two very basic operations: indexing columns from a 2D array and autoindexing an 1D array using a loop…
Btw. your "X Y" array contains 5 columns even though you decided to show only the first two columns!
Message 7 of 18
(3,824 Views)
Thank you so much again!
I didnt show the VI because im using property nodes to move the microscope stages and it wouldn't work if i put it here.
Its exactly what you did is what i tried to do.
The problem is: the property (node to move the x stage) takes just integers as input. And when I connect to the autoindexing loop, it tells me The type of the source is long [32-bit integer (-2147483648 to 2147483647)].
Message 8 of 18
(3,818 Views)
This makes absolutely no sense. The "source" is your value and the "sink" is what the property node expects.
You need to show us your code, even if we don't have your instrument.
What kind of property node is this? Part of a driver package? Do you have documentation?
Message 9 of 18
(3,815 Views)
I did a simplified VI where i can show the problem, i hope that the property node shows if you open the VI.
thank you so much in advance!!
P.S.: i cant put the property node in the autoindexing loop, in the big VI that woukld be too complicated 😞
Message 10 of 18
(3,805 Views)
