Reading values from multiple DS18B20 digital temperature sensor
I have managed to create a VI that read sensor value from only one DS18B20 with the reference of examples found online.
The sensor is connected to connector A -- +5V, Gnd and DIO8 with pull up resistor.
How can I increase it to two sensor readings. I understand I need more use more ports, I am having issue with modifying FPGA VI.
Please help thanks.
Message 1 of 1
(2,253 Views)
