Reading whole excel file
Hi all I want read whole excel file
please guide me.
Message 1 of 10
(2,053 Views)
Hey, Can I get the same but want to read it. no write
only read.
Message 2 of 10
(2,026 Views)
Hi Basvaraj,
The same as what exactly?
only read.
You want to read a text file using an Excel import routine? Why???
What do you really want to solve?
Message 3 of 10
(2,035 Views)
Basically
I want to read the whole excel file as it is.
so, I can perform some operation like searching particular number\name and get the whole data related to it like date time, pass or fail
this vi (screen shot) is write at particular cell.
Message 4 of 10
(2,030 Views)
You need to change the input from a string to a 2D array, and you can remove the starting cell range to read the whole file.
Message 5 of 10
(2,044 Views)
Thank you for your reply
IT WOULD BE NICE IF YOU SAVE IT FOR 2018 VERSION
Message 6 of 10
(1,995 Views)
Accepted by topic author Basavaraj093
Message 7 of 10
(1,993 Views)
Thank for your reply.
I am now reading a whole excel file.
Do you know how can i search particular word in that.
like if I search serial number, it should give me whole row related to that serial number
like date time status
Message 8 of 10
(1,967 Views)
I would read in the whole Excel file and then do the search in LabVIEW to get the row you want. It's probably faster that way. But if you really want to search look at this VI.
Message 9 of 10
(1,940 Views)
i will check
Message 10 of 10
(1,924 Views)
