If your time-based signal is unit X, then the real FFT function will give you X rms^2. Use Spectrum Unit Conversion.vi to get you the X peak-to-peak if that's what you want.
You can find that VI from the Function palette at Analyze >> Signal Processing >> Frequency Domain >> Spectrum Unit Conversion.vi (bottom row, second from left usually).
Are you trying to analyze the signal from a dynamic pressure transducer? Perhaps trying for combustion dynamics monitoring? We do that stuff.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
