Real Time Absorbance for Ocean Optics spectrometer with OmniDriver
Hi, I am new here.
I am developing a LabVIEW code to measure real time absorbance for Ocean Optics spectrometers with OmniDriver.
I used "SetAcquisitionParameters_NET" file provided by OmniDriver sample pack for multi-spectrometers.
It is working well for normal scope mode intensity measurement with integration time, average to scan, and boxcar width. But, I do not know how to collect real time absorbance data with reference and noise data like SpectraSuite software does.
Could anyone tell me how to program this?
Message 1 of 9
(4,305 Views)
Good Afternoon,
I am not sure what your exact spectrometer is, however, there are many drivers for Ocean Optics products at ni.com/idnet.  If there is a LabVIEW driver for you spectrometer here, then you can use the API within that driver to acquire the desired data.  Hope this helps!
-Cody C
Message 2 of 9
(4,289 Views)
Cody C,
Good Morning. I am using S2000 and HR2000 now. I will try what you suggest. Thank you.
yoralph
Message 3 of 9
(4,267 Views)
   As long as your S2000 has an USB ADD, you will be able to use it with OmniDriver-SPAM.  The HR2000 will work fine.
  Here are two good videotutorials that will show you how to use OmniDriver-SPAM with its LabView dll to acquire spectra:
http://spectroscopytv.com/2009/02/02/omnidriver-labview-part-1/
http://spectroscopytv.com/2009/02/02/omnidriver-labview-part-2/
  Hope this helps,
R
Message 4 of 9
(4,259 Views)
Forgot to add that for the Absorabnce, you need to use or have SPAM (Spectral processing and manipulation - OmniDRiver component). http://www.oceanoptics.com/Products/omnidriver.asp
In SPAM you need to use the class: CoreAbsorbance
And the method is: processSpectrum()
Cheers,
R
Message 5 of 9
(4,258 Views)
Hello there, can u be more specific how to use the class with SPAM in labview especially to measure absorbance.
Message 6 of 9
(3,849 Views)
  Please see attached example VI.   In Labview 8.6, 32 bits.
Thank you,
R
Message 7 of 9
(3,829 Views)
Hi sir,,
I have tried to run this program using LabVIEW 2014  64 bits.. but it has got problem with the NetCoreAbsorbance. Should I use LabVIEW 8.6 32 bits for running this program?
Really need this info.
Thank you
Message 8 of 9
(3,550 Views)
Hi R,
Thanks for your example. I really appreciate it. Can you share another examples to calculate CCT,CRI, Purity,x,y,Ra-R14? Hope to hear from you soon.
Message 9 of 9
(3,193 Views)
