I have a problem with the Real Time Execution Trace Toolkit.
I created a very simple programm to find the problem.
The problem is that the Trace file is empty every time. I found out that every thing is fine if I use LV2020 and the RT Image 20.7. But if I use a higher version of the RT Image the problem occurs. I don't receive an error massage, just the created file has only 20KB and no recorded traces. With RT Image 20.7 the file has a size of around 40 KB and some traces are shown.
Has anyone an idea what the problem could be?
Here is my test code:
Many Thanks
PS: For my first tests I used LV2022 and RT Image 2024 Q3. It means that newer versions don't solve the problem.
