Real Time Scan Mode with cRIO 9024 in Windows OS
Dear All,
I want to know Windows OS is compatible with CRIO to be used in Real scan mode?
I am writing code with reference to this page:  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0UdCAI&l=en-US for
Data Acquisition. In step 23 under Using the CompactRIO Real-Time Scan Mode, it says
Create constants for the file path and operation inputs. Which path will be used in case of windows as it is not RTOS.
Thank you
Regards
Zohaib
(2,808 Views)
Accepted by topic author ZohaibRamzane
The step 23 in above link gives an idea on how to create the files in different RTOS (NI-Linux, Pharlap or Vx-Works) running on cRIO.  Your cRIO will have it's own drive storage and that's mentioned here as C: or /home/.  I guess you're confusing here between Windows OS and RTOS.
Ajay MV
(2,799 Views)
You are saying here RTOS means the OS in cRIO?
or
Can you a little elaborate?
(2,795 Views)
Yes, RTOS is the OS running in cRIO target.
Ajay MV
(2,769 Views)
