05-19-2008
06:28 PM
- last edited on
06-01-2026
08:25 AM
by
Content Cleaner
Post your questions and feedback to the Real-Time Sequencer Architecture and Real-Time Sequencer Architecture Example here.
10-01-2010 10:30 AM
I just purchased the USB 6341 DAQ card. I am using Dev1/.Port1 to control 4 driver transistors. The transistors fire 4 SSR. I am trying to create a sequence for the 4 transistors. Sometimes a test unit that is driven by a SSR will fail. So I have to change the sequence for the failed DUT.
Basically each SSR will be ON for 6 seconds. There will be a delay of about 5.75 seconds for the next valve to fire. The delay is used to balance the pressure testing. The second valve will need to start at 5.75 seconds later. Basically the two valves must cross at the 50 % turn OFF. How can I perform this task. There are at least 7 different test sequences??
Philip
10-01-2010 10:33 AM
This is a forum for the Real-Time Sequencer Architecture. I would choose another forum for DAQ and programming questions.
10-01-2010 11:00 AM
OOOPS My mistake.
