Real Time Signal Processing
I am wondering if you could recommend which LabView products could help me in my application.  I need to input sound through a microphone, do some signal processing on it, then output this to headphones.  I was planning on using a PC to do this.  I wanted to input the sound through the sound card, use LabView to process this, and then output that to the sound card again.  It is important that I do this in real-time, and I am not sure if I can get good results using the PC.
I was looking at the NI Speedy-33, but it looks like that is only for educational use.
Can this be done using a PC? And if not, do you have any products you recommend to try?
Thanks.
(6,542 Views)
Did you look at NI's Sound and Vibration Toolkit?  Using a hign end S-Series or DSA card my work but won't get real-time.  Delays maybe measured in 10s to 100s of milliseconds.  Only way to get Real-Time is to use the FPGA products.  Delays will still be measured in nSEc or uSecs.  Sound and Vibration Toolkit will not work with FPGA products.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(6,534 Views)
For my application, I need to have real time.  I have been looking at LabView Real Time to do this.  With LabView Real Time, I will need to buy another piece of hardware (like a PXI).  This seems to be more than I need.  I only need to have 1 microphone input and 1 headphone output.  Is it possible to do that using LabView Real Time?
Also, using an FPGA could work.  Do you know where I can find information on using FPGA's and LabView?
Thanks.
(6,527 Views)
The links below will give you more information on LabVIEW FPGA module.
LabVIEW FPGA Module Product Page
LabVIEW FPGA Module Training
Your best bet for a real-time solution is probably our CompactRIO line.  For more information, click the link below:
NI CompactRIO Control and Acquisition System
Please let me know if you have any more questions.
Craig D
(6,137 Views)
