Real-Time System Manager "Instance" Message in the VI State Column
I am developing a Real-Time System and when I use the Real-Time System Manager, I see that there are some VIs listed multiple times.  The additional listings have  "Instance ## ##Saved" ahead of the name.  The ## signs represent where some numbers would be.  This would make sense to me if these where Reentrant VIS, but the are not.
Anyone come across an explanation for this?
(2,377 Views)
Chris,
Are you using any Express VIs by chance? This is a behavior that will show up with Express VIs.  If you are not using any express VIs, I am not sure -- I have not seen that behavior before with normal VIs.  If you can reproduce this behavior with a very simple project you could post it and I could take a look.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,365 Views)
