Real time clock synchronization on a peer to peer network
We have a small peer to peer network which is not connected to the internet. We would like to use the real time clock on on of the PC as a time standard to synchronize all the other real time clocks on th eother PC on the network. Does anyone know how to do this?
(2,918 Views)
Not sure if this is what your looking for put check out the following
http://www.han-soft.com/nettime.php
I also think there is a Net Time DOS command and that may work as well if I understand your question correctly and it would be free
You can find info about it at http://www.windowsnetworking.com/articles_tutorials/nettime.html
hope this helps
Cheers,
--Russ
Message Edited by Russ Evans on 06-08-2006 12:20 PM
(2,909 Views)
Net Time in a dos box works
Many thanks
Steve
(2,888 Views)
I've used About Time (which is free), and found it very useful, keeping a peer networked in time synch for two years with zero maintenance and less than 5 minutes per machine to set up. It will also fetch the time off an internet time server. I've just checked to make sure that it is still available and still free.
http://www.arachnoid.com/abouttime/
For lots more information on time and timekeeping, have a look at
http://www.npl.co.uk/time/
http://tf.nist.gov/timefreq/index.html
Rod.
Message Edited by Rod on 06-09-2006 01:37 PM
(2,880 Views)
