Real-time data Processing
"...how quickly should it cycle?"
That depends on the nature of your calculations. FFT's of large data set will take a long time. Just scaling and comparing with a value will be done before you start.
Ben
Message 11 of 13
(697 Views)
Agreed.
Also, is there a way to read only the newly acquired data, such that the entire data set isn't constantly read over and over again (thus being highly repetitive)?
And, as previously asked, what kind of loop is commonly used for such a read-process-write application?
Message 12 of 13
(694 Views)
"And, as previously asked, what kind of loop is commonly used for such a read-process-write application?"
With info on what architecture you plan to implelment this Q is a lot like asking "What kind of adhesive should I use?" before you have determined you are working with steel or plastic.
So my reply is "insufficient data to complete this operation."
Ben
Message 13 of 13
(690 Views)
