Real-time flow monitoring
Hello everyone,
It is just a simple question, I am a learner.
I got a DIO NI-9401, and it has been used for measuring flow rate by a edge counter task. It is working, but I don't know how accurate is this.
So, I would like to know your opinion. Would be better a task to count edges or frequency (how many pulses per second)?
Thank you in advance for sharing your experience.
(518 Views)
Hi Vini,
Counting edges to calculate a frequency (probably based on iteration time of your loop) is basically the same as using a DAQmx frequency task.
There are some subtle differences:
  • DAQmx will use its internal timebase, which is probably more accurate than host computer timing.
  • The frequency task will probably have more problems with very low frequencies (aka "no flow" condition)…
(497 Views)
