Real time in waveform?
Message 11 of 33
(1,121 Views)
And one more thing, The data you want to plot is dynamic or static i.e. it is already stored or you reading and sending directly to graph with x axis as time.
Let me know what is approach..I don't have DAQ so cant verify here
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 33
(1,112 Views)
Tell me what are the datatype you are using for Y axis and is it array or direct data
--Ranjeet
Message 13 of 33
(1,109 Views)
Try this VI and let me know
--Ranjeet
Message 14 of 33
(1,107 Views)
I need in this VI two graphs. One is for imidiately record voltage data from measuring card andsecond is for long time record. I am reading data form USB 6009 and sending directly to graph.
Message 15 of 33
(1,104 Views)
See the problem is in 1 graph you are displaying dynamic data & in other graph static data. Why you are doing this ?
What is the need that both graphs should be in same front panel.
If i am not wrong then in both the graphs you need x axis as time stamp right ?
My last attachement will answer for your dynamic data if you are looking for thatSmiley Very HappySmiley Very HappySmiley Very Happy
--Ranjeet
Message 16 of 33
(1,093 Views)
Data comes form solar panel. I have to collect these data (voltage) and show over USB 6009 on PC. So I need show in one graph floating actually voltage and in second graph long save voltage (in hours/days). So if you know what I need, do you have any idea how can I make it?
Message 17 of 33
(1,086 Views)
The data coming from solar panel will have some gap i.e. you are going to read in the interval of 1 or 2 seconds and you want to show this on graph with x axis is time stamp, right ?
If this is the condition then use this VI
let me know..
--Ranjeet
Message 18 of 33
(1,032 Views)
Yes, I want. I watched on your VI. It works but I have problem that time is going faster then in real. Its doing in your VI and same if I used in my VI. Where is mistake?
Message 19 of 33
(1,014 Views)
Try this & let me know
--Ranjeet
Message 20 of 33
(988 Views)
