Real-time plot with changing acquisition rate
  Sorry. i forgot to attach my project setup. I attached that setup pic here.
Message 11 of 16
(994 Views)
It appears you don’t have any VI under your cRIO controller.  You can’t just go directly from your FPGA to the development computer.  You need to go through the controller.  The FPGA talked to the controller, then the controller talks to the PC.  Therefore you will need to setup this communication as well.
I would suggest looking at the FPGA Tutorial linked below for additional help.
NI Developer Zone: FPGA Design, Development and Programming Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3358
Mike S
NI AE
Message 12 of 16
(974 Views)
      Thank you so much. Please tell what modules i need to add in the fpga VI. For my application  I have  to take  the wave form signal from NI-9221.
Message 13 of 16
(960 Views)
I would suggest looking at some of the shipping examples for an idea of how a cRIO project should be set up.  You can access them by going Help>>Find Examples from within the LabVIEW environment.  My suggestion for one to get started with is under Hardware Input and Output>>CompactRIO>>Basic IO>>Analog Input – cRIO.lvproj.  Take a look at this example and see where everything is.  From there you can translate this into your project.
Mike S
NI AE
Message 14 of 16
(938 Views)
sir,
Just tell me. Is it possible to take graph  for 120khz singnal (the signal is speed of wheel with 6000rpm)with NI-cRI 9221.
thank you
Message 15 of 16
(895 Views)
Is your 120khz signal from an encoder?  Most encoders generate a digital PWM signal that can be read with a counter.  The NI 9221 is an analog input module that cannot read digital signals or give you access to the counters.  I believe you would have more success with a NI 9401 or NI 9402 which are our digital modules.
NI 9221
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14590
NI 9401
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201849
NI 9402
http://sine.ni.com/nips/cds/view/p/lang/en/nid/204678
Mike S
NI AE
Message 16 of 16
(886 Views)
