Real time reading from string control
Hello everyone,
I am trying to create simple Vi which should read input real time like when you paste anything in it it should displayed in output indicator. But in my this Vi I used event structure for detecting value change in the string Control.
But when I input something, I need to click outside the string control then only it is displaying on the output.
Actually, I am using this for like when scanner is scans the barcode/QR code the data should display in the indicator. without clicking mouse.
is it possible?
(2,063 Views)
Accepted by topic author Basavaraj093
Right-click the string control and check 'Update Value while Typing'.
(2,058 Views)
Check the Barcode Scanner to configure it to send a CR at the end of the string, then it will trigger the Event structure and LabVIEW will recognized it and enter the string.
(2,054 Views)
Thank you for your reply it is working😊.
(1,986 Views)
How to check it, I don't know actually.
(1,983 Views)
