Real time voltage measurement from Keithley 2400 Sourcemeter. How to increase chart update rate?
I'm trying to view the voltage measurements in real-time chart. (Labview2012 and I've connected 2400 sourcemeter with my laptop by using GPIB-USB-HS)
My question is, how can I increase the chart update rate? Say, how can I increase samples/second rate?
Here is the screenshot of my chart -> Untitleda.jpg. Its update rate is quite slow and I dont know why the voltage measurement takes time to settle back 0V (notice the descending slop after the voltage pulse).
I'm using labview to measure a voltage pulses. So I need fast-response chart that looks like this -> Untitled.jpg.
I'm very new to Labview. Please help Smiley Sad
I'm attaching the vi
(7,083 Views)
I am not able to look at your VI's right now.  But I had to communicate with a Keithley 2000 yesterday over RS232 and I ended up using the fetch command instead of the read command.  I ended up reading a few posts on the forum that recommended doing that.
(7,061 Views)
Are you sure they're the same timescale?  The LabVIEW shot sure looks like a time-stretched version of the display photo...
Bill
CLD
(Mid-Level minion.)
(7,039 Views)
I replaced "Read" to "Fetch" command as shown below;
But, I'm not sure if I placed it correctly since I'm very new to Labview.
Although I'm using "Fetch" command now, I can't feel any speed increase in the chard update rate..
(7,034 Views)
As I mentioned yesterday... are you sure the timescale is the same?  Your plots sure look similar, with your LabVIEW plot being a much smaller slice of time.
Bill
CLD
(Mid-Level minion.)
(7,005 Views)
