Really challenging, Really Tough Array problem
I'm working on a parsing problem. I need some help regarding storing numbers in a string to a arrays. I have a text file shown below,
TEXT FILE
N1 G98 G12 G21
N2 G14 G34 M43
N3 G65 M10 T84
N4 G96 T02 M62
I want to store all numbers that appear after each G in Array1, numbers appearing after each M in Array2 and number appearing after each T in Array3 in such a manner as shown below,
ARRAY 1
   0         1       2       3        4      5      6     7      8
: 98   :  12   :  21   : 14   :  34  : 65  : 87 : 96  :  :
ARRAY 2
   0         1       2        3        4      5      6     7      8
0    :    0   :   0    :   0    :  43  : 10  :  0  :  0  :   62 :
ARRAY 3
   0         1       2        3        4      5      6     7      8
:  0    :    0   :   0    :   0    :   0  :  84  :  0  : 02  :  0   :
Notice in the above arrays that when an M appears after the 4th G in the text file then the number after M has to be stored in the 4th element of Array2 and when T appears after the 7th G, then the 7th element of array2 is made 0 and 02 is put in the 7th element of array3, and so on..............
Message 1 of 17
(4,313 Views)
Just take each token string, split after the first character, convert the tail to a number and append to the appropriate array depending on the first character.
The attached example (LabVIEW 7.0) shows a simple implementation. See if it works for you. 🙂
Message 2 of 17
(4,314 Views)
Hi Altenbach,
Thanks a lot for the VI. Your VI has really helped me in my parsing project. You are too good. Now I'm almost done with the main part of my project. The whole credit goes to you.
We'll keep in touch.
Giridhar Rajan
Automation Engineer
Cruiser Controls
Mumbai, India
Message 3 of 17
(4,297 Views)
Hi Giridhar,
Have you noticed this thread?
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=854&jump=true
Ben
Message 4 of 17
(4,292 Views)
Hi Altenbach,
This is with reference to the VI (GMT.vi) that you made for me to seperate numbers appearing after each G, M and T from the following text file,
TEXT FILE
N1 G98 G12 G21
N2 G14 G34 M43
N3 G65 M10 T84
N4 G96 T02 M62
It was really great. Now I want to add a bit more complexity to this VI. Now my text file looks like this,
TEXT FILE
N1 G98 G12 G21
N2 G14 G00 X0 Y10 Z50 F100  M43
N3 G65 M10 T84
N4 G96 T02 M62
Notice the string X0 Y10 Z50 F100. I want to store all such strings that appear after each G00 till the next G,M or T appears on the text file to a string variable. After storing this string in a variable, I'll again apply technique in GMT.vi to seperate numbers appearing after X, Y, X and F. Please help me out with this. I have attached the VI below,
Message 5 of 17
(4,255 Views)
Here's one simple possibility, maybe it is good enough for your purpose. (It will be a little bit more complicated if you want the exact string instead of the reassembled tokens).
Message 6 of 17
(4,252 Views)
Hello sudhir,
I only want to make a comment, as Altenbach was faster:
Please do not include a case for every number from 0 to 100 if you only have 2 cases that do something. Use ranges of numbers and set a proper default case!
Message 7 of 17
(4,247 Views)
Thanks a lot GerdW for your suggestion. I've not yet added functions to those cases left empty. Keep in touch.
Bye
Giridhar Rajan
Automation Engineer
Cruiser Controls,
Mumbai, India
Message 8 of 17
(4,237 Views)
Hi Altenbach,
Thanks for the VI. Is there a way to obtain the string X0 Y0 Z0 F100 inside the case G0 instead of obtaining it outside the while loop. This is because I want to use that string in the Case 0 that runs inside Case G in runtime and feed the value after X, Y, Z and F to the axes of a motion control card.
Giridhar Rajan
Automation Engineer,
Cruiser Controls,
Mumbai, India
Message 9 of 17
(4,215 Views)
Hello sudhir,
that would have been my proposal:
in the G00 case put a "Search Pattern" with pattern [GMT] and search from the position after G00. This way you get the position of the next G,M or T token and so you have the  position (start,end) of the XYZ-string. Now  you can use this string to feed a "scan from string" with it - all inside the G00 case.
Message 10 of 17
(4,210 Views)
