Rearranging global variables.
Hi there
Just have a question if you can rearrange the global variables menu list?
I would like to arrange the global variables in a meaningful way but for now the last created global variable is also the last in the menu list.
So is there a way to influence the list?
Peace
Waldemar
(2,899 Views)
Try going to your globals "vi" and in edit select "Set Tabbing Order".
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,889 Views)
Hay thanks.
That works beautifully. 🙂
Peace
Waldemar
(2,874 Views)
