Rebooting System due to Exception 0xC000005
Hi, I am getting this error randomly on the PXI RT controller on multiple systems. I have Labview RT 8.2.x and 8.5.x which have the same issue. Can some one help in pinpointing what is the source of this error.
Ashm01
(3,101 Views)
Hi ashmo1,
                     Please see this thread
(3,082 Views)
the 0xC0000005 is the "classic" Access violation. This exception happen when your software try to read or write on a not allowed memory area. In pure C this typically happen when you use a pointer that hold an incorrect value (point to a reserved memory area).
I don't know exactly how the memory is managed in an RT system, but I think that you have more control (and more chances to create a bug) than in a regular LV-under-Windows.
I can only suggest to you to start checking how data are passed between various sw module/sub-vi (data type, array size, by ref/by val ecc...).
(3,072 Views)
