Rebuilding a single precision float from 4 discrete bytes
@chilly charly wrote:
BTW, could somebody try to explain me why extended precision numbers use only 10 bytes. I believed that 12 bytes was the standard.
CC
Have a look at Application note 154. Extendend precision is platform dependent (10 bytes on Windows/Linux (80bit IEEE EXT) and 16 bytes on MAC (Apple double-double format) and Sun (IEEE 128bit EXT).
To keep flattened EXT data platform indepdendent, it is always stored in 128 bit sun EXT format.
Message 11 of 15
(1,213 Views)
Ha !
At last, that could an objective reason to prefer MacIntosh : to be able to get 14 more decimal digits.
However, on my Powerbook, it seems that the 7 last bytes are alway equal to zero (Extended coded on 9 bytes ???). Should I throw it directly to the garbage ?
CC
Chilly Charly    (aka CC)
Message 12 of 15
(1,035 Views)
Are you on OS X?
Message 13 of 15
(1,030 Views)
@altenbach wrote:
Are you on OS X?
yes !!! I have been told that LV7.1 was not running on OS9...
CC
Message 14 of 15
(1,022 Views)
Altenbach and CC, thanx for clearing up a subject that has been bothering me for a long time.
- tbob
Inventor of the WORM Global
Message 15 of 15
(1,016 Views)
