Reccomended Temperature-Humidity Sensor
NOTHING is easy - anything and everything else is the problem...
Message 11 of 17
(4,287 Views)
Hi alls,
I finally come up with HygroClip2 and also with Sensirion.
Both worked although it took me almost a week to figure out.
Thanks again for your help.
ThanhVan
Message 12 of 17
(4,277 Views)
Silabs are bringing out RH & T Sensors with digital I2C output on Standard (commercial) grade CMOS with 3 & 5%RH accuracy and 1 and 0.5 degC accuracy.
Beta sampling taking place right now with mass sampling after the summer. Contact david.boylan@silabs.com for further details.
Message 13 of 17
(4,258 Views)
@thanhvan wrote:
I am looking for Humidity-Temperature Sensor which will be used with LabVIEW through  NI-PXI 6220.
I do not need the high solution sensor (+/-0.5C), but an easy to use as I am new with LabVIEW. To control the temperature and humidity of a chamber by measuring current data and turn ON/OFF the heater/humidifier when needed.
Is there any example for me?
Your reccomendation is highly appreciated.
This is not a sensor but a piece of test equipment to measure temperature and humidity.
I was searching for something to add to our current test station to measure termperature and humidity.
http://us.flukecal.com/products/temperature-calibration/digital-thermometer-readouts/1620a-digital-t...
Message 14 of 17
(4,222 Views)
Hello Tim,
I have a very old version of Labview, is there a chance that you can convert this VI to an older version, I have labview 7
Jorge
GE
Message 15 of 17
(4,080 Views)
I recommend using the sensor RHT03 Sensor, there are many examples of this type of sensor
http://kesslerarduino.wordpress.com/2012/06/13/rht22-rht03/
Message 16 of 17
(3,955 Views)
It's been a while...
For simple connectivity I recommend the VINT solution from Phidget. Please note that for USB connectivity, you'll need a HUB as well... if you prefer, you can use your own DAQ, and not use the HUB.
Message 17 of 17
(3,310 Views)
