Receiving/Reading/Writing data stream to-from PXI-8513
I have a PXI-8513 connected to an IMU that I want to be able to read the hex data stream from it as well as parsing it as every byte has information about the products I am working on. Reading the data stream and parsing it is the challenge. Also, CAN or XNET as devices are connected through ethernet.
I have attached a sample screenshots of the NI-XNET and my code in progress.
(3,586 Views)
Hi mjafarin,
If you're starting out using NI XNET (or CAN), I'd recommend taking a look at the shipping examples as well as these documents as reference:
Getting Started with the NI-XNET API for LabVIEW
NI-XNET Hardware and Software Manual
It sounds like you're working on creating a frame input stream, so the "CAN Frame Input Stream.vi" example should be a good starting point.
(3,532 Views)
hey could u please repost the link. its disapert
(933 Views)
