Recognising my software
Hi
I am also having an error: 10007 problem with my VI Logger programme as part of the Labview which comes up as a problem with the AI Group Config (A channel, port, or counter is out of range for the device type or device configuration; or the combination of channels is not allowed; or the scan list must be reversed. (0 last).).  I have several devices (11 in total) that I am trying to get to read information from.  Unfortunately only 4 of them are running logs.  I am running it with a data acquisition card DAQ - AI 16E-4 which converts a voltage into a pressure trace. All of my channels work.
I have changed all the different codes within the traditional NI-DAQ section, tried changing the scales, tried to install and uninstall as well as configure the DAQ card (with differential and referenced single ended) within the Devices and Interfaces section and the system is still not running. Some of the transducers are outside of the sensor/actuator range but others are within the range and yet still do not work.  All the transducers work in Labview but don't work in VI Logger.
How do I get those that are not picking up information to do so?  Anybody any ideas?? Please help!
Cheers
Alexis
I have posted a string under error 10007 - signaling conditioning as well.
(3,119 Views)
Help!
Still need some help!
(3,084 Views)
(3,054 Views)
