Reconstructing signal from FFT
Well, clear as mud i would say.
My biggest concern is: What do those 10 averaged values tell us?
Or to turn the question around: What is it what you are looking for? How should your resulting time signal look like?
What i see is:
40k Samples => FFT with 40k values => Average to a single scalar (sum/40k) => Build an array of 10 such averaged values => inverse FFT => ??????????????
So the time signal will result in something with 10 samples.....
Norbert
Norbert
Expert: Geometry
Message 11 of 12
(696 Views)
What i see is:
No Norbert it is not what i'm intending to do
i wanted
40k Samples => FFT with 40k values => Collect 10 sets of such 40k samples => average them element wise so that finally i m left with 40k scalar values of which each element is a average of corresponding 10 elements => inverse fft
and i tried a little bit of coding and i m now successfully getting what i wanted. I just had to average out 10 stances of waveform graphs (of i second each)
Thank u all for responding
I am actually working on Fluid structure interactions, so i want to see how the pipe vibrates with respect to speed of fluid in it.
Message 12 of 12
(687 Views)
