Record Time elapsed for a boolean button status change
I am new to Labview and am trying to implement a simple program. I want to find the time elapsed in seconds when a button value is true to a changed button value of false. I created the following VI attached for the same but the timer runs only until 50 seconds and then resets to 0. I am not sure why, but i didnot click any autoreset in this express VI.
Can anyone help me?
N
(2,846 Views)
Accepted by topic author Maverick269
@Maverick269 wrote:
... but the timer runs only until 50 seconds and then resets to 0. I am not sure why, but i didnot click any autoreset in this express VI.
If you double-click the express VI, you'll notice that it is configured for 50seconds. Set it to a very high number, such as +inf 😄
(I don't understand why you need a value property node? Just wire to the control terminal directly.)
(2,826 Views)
Yes That works. I am using a property node as I am not working on the VI which actually has the control.
Nisha
(2,790 Views)
