Record temperature continuously as function of time per second while the the temperature changes every 15 minutes
Hi All,
I am trying to heat a effusion cell for a deposition system using a eurotherm controller. Currently I use a manual slider to change the temperature every 15 minutes while logging the real time temperature every 1 second. I am trying to automate the manual part where I want to ramp and soak from a defined minimum to a defined maximum say evry 15 minutes but want my data logging of temperature as a function of time every second. Not able to find a simple way to execute this. Any suggestions will be helpful.
(589 Views)
You do know, don't you, that LabVIEW is capable of parallel processing, right?  You can have one loop running a loop to once/sec to take a temperature and log it to a file.  You can have a second loop (I'm putting this in quotes because I don't know what it meanjs) "to ramp and soak from a defined minimum to a defined maximum say evry 15 minutes".  LabVIEW provides timing functions that should keep the loops running as separate parallel loops without getting "out of synch" for hours/days, maybe even weeks.  It's also not so hard to consider a single loop (running at 1 Hz to collect temperature data) that takes temperature every loop and does the "slower stuff" every 10, or 30, or 100 loops.
Bob Schor
(569 Views)
