Recording an avi file through a USB camera
I am trying to record an avi file of a video captured using a USB webcam but cannot get the file to record. My code is attached, if anyone can point me in the right direction i would be very grateful.
(2,647 Views)
Hi iron_maiden09,
I am trying to inspect your code and recreate the problem here but a number of the VI's used are missing. Which versions of LabVIEW and the relevant drivers are you using? You can get this information through the Measurement & Automation Explorer (MAX) under the Software tab. I can then install the relevant driver on my machine and hopefully recreate your problem.
Best Regards,
Christian Hartshorne
NI|UK
(2,620 Views)
