Recording measured voltage and current values from LCR 4284A
I want to use the labview VI to record the measured voltage and current values from LCR 4284A. These are shown as Vm and Im on the instrument screen. Is it possible to record these values using a VI?
I have looked through the drivers that are available through the "Instrument driver network" (Link) for 4284A but none of the VIs give any option to monitor Vm and Im. If you know how this can be done then I would really appreciate a reply.
Mansoor
(2,896 Views)
I haven't used the instrument but there are functions to enable/read voltage level and current level monitors. Are those different than what you are asking for? What does the manual say about Vm and Im and programatically getting them? If you can find the command in the manual, you can just open the VI Tree and do a text search for the command.
(2,889 Views)
