Recording of signal in waveform for analysis
Hi all,
I have three different waveforms being generatred using DAQmx. I am measuring current,position and voltage signal. I want to know the efficient method I can record my signals to analyze them later. I want to also remove unwanted noise from signals.
(1,445 Views)
Hi learner,
Store those waveforms in a TDMS file.
Use the example finder in LabVIEW to find examples explaining how to do that!
Define "noise"!
What may be noise to you might be sueful signal to others…
(1,442 Views)
Okay, I have tried the TDMS option. I used write to measurement and used TDMS as my file format type. I am recording it for about a minute, looks like it has store about 20 TDMS files on my computer including some backup files. Is this pretty normal?
(1,400 Views)
Hi learner,
It depends on your code.
Unfortunately you forgot to attach your code…
(1,371 Views)
Hello All,
As the title says, I am working with .mat file which has data that have collected from testing. I am analyzing this data and it contains unwanted noise which I want to get rid of. I have some experience with signal processing and some understanding of filters but I am fairly new to LabVIEW.
I tried by adding filters by functions pallet selecting signal processing and choosing one of the filters from the drop down. This doesn't seem to work and I think it's not as straightforward as I may think. Do I need to calculate frequency or anything. Please tell me where to start
Can some please help and share how I can achieve a pure signal. Please provide me with resources.
(1,374 Views)
