Recursive reference with no shared reentrancy
any ideas how to fix this problem. keep getting told :Bad linkage to subVI
        : Recursive reference with no shared reentrancy.
I know how to relink the first problem just when I fix the second problem from steps on google it seems to berunning in a continuous loop?
(4,015 Views)
You have a VI that's trying to call itself - this is a recursive call. You can only do a recursive call in LabVIEW if the VI is set for shared clone reentrancy (in VI Properties -> Execution). However, in your case this looks like a really bad idea, because if sending the email fails, it will try again, and if that fails, it will try again, etc - in an infinite loop that will stall your program and eat up all available computing resources. Why would you want to do that?
(3,997 Views)
Your subVI reentrancy is set to "preallocate clones", which is not allowed for recursive calls (i.e. when a VI calls itself, as in your case). The compiler cannot know how many clones are needed and only shared clones are thus allowed.
I agree with natahnd that your code logic seems flawed overall. What are you actually trying to do?
(3,991 Views)
Sorry forgot to mention this isnt my code, i inherited with a new job as part of college and old coder has left so trying tofigure it out myself. The code was working fine but while i was editing may have edited something i shouldnt have and am now seeing these error that i cant figure out how to resolve
(3,964 Views)
Do you have a source control system or other backup of the original code so you can see what you changed? We've already explained the reason for the error and why the current code is a bad idea. There's no way to guess what you might have changed. If you don't have a source control system, set one up immediately. Consider Mercurial, which I believe you can set up locally without a server, and move to a server later if you have more developers working on the same code later. (Of course, if you use a source control system local to your machine, you should have some other backup.)
(3,934 Views)
