Redesign shape of front panel raised frame decoration?
Hi all, does anyone know of a way to redesign the shape of front panel decoration; Modern - Raised frame?  I would like a 'L' shape design.  I tried using the single line shapes but their design pattern differs from the raised frame and since I am using this elsewhere, it looks a bit out of sort.
(3,258 Views)
As far decoration if you want to make L shape place a square of raised box then keep another box which is smaller than that and make it transparent.
(3,255 Views)
You could construct using thick chiselled lines
(3,246 Views)
Sorry, just had another look. This would only look right if you used recessed frames for your other decorations.
(3,241 Views)
@gyty wrote:
What a question about. To save the chart and read the chart.
An attachment.
You need to start your own thread, rather than adding to another, unrelated one.
(3,221 Views)
