One thing you might look into would be to place a tab control down, create a tab for your main front panel and one to include an ActiveX container, which you can use to display another webpage. Once the condition has been met to redirect the user to another page, you can then switch tabs to the ActiveX container and load the webpage. Hope this helps!
Andy F.
