Redirecting stdout/stderr/stdin to/from LabVIEW in dlls.
In C, the 'printf' statment will write to the __stdout of the console. There is a supposed example of how to capture the stdout in labview here:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Access-to-console-output/idc-p/1768066
but I can not seem to get it to work in the way described above.
Message 11 of 13
(1,972 Views)
Are you able to get the example to work? If not try that and then try modifying your code incrementally so you can see where issues are occuring.
JY
Application Engineer, RF and Communications
Message 12 of 13
(1,950 Views)
I can confirm this is not working as of LabVIEW 2017. LabVIEW crashes painfully so finding where it stops working isn't really a reasonable approach.
Message 13 of 13
(1,541 Views)
