Redraw without reset
Two things:
I add plot point annotations using the mouse down event.  This causes the annotations to be added even if using the mouse to zoom in.  Is there a suggestion for how to detect which graph control is selected (I only want to add the annotations when the crosshair button is active).
Also, on adding annotations.  When they get added, sometimes they are partially drawn.  Refreshing the graph clears that up, but it also resets the graph zoom.  Can the refresh method be called to refresh with the current zoom intact?
XL600
(3,113 Views)
Accepted by topic author xl600
Try the Palette >> Active Tool property. It looks like 0 = crosshair, 1 = pan (hand), and 2 - 7 = various zooms.
(3,067 Views)
Had to be something for that available.  Thanks!
(3,060 Views)
