Reduce System Memory Usage While Saving Waveforms
Made a few updates. Also took snippet since I think people prefer that.
Message 11 of 16
(2,294 Views)
One there is a bug in your code.
  1. Assume I have 100 points in your tester.
  2. dt equals 0.001
  3. The final time should be 0.099 (Starts at 0, hundred points later including 0 is 0.099)
Look below at your spreadsheet, mine is next to it as a comparison.
Can you see the difference in numbers? (dt is 0.001) Can you identify your sheet?
Below is a NEW working version that should sip less memory and maybe faster as some loops are parallelized. The zip file is saved in LabVIEW 2018.
All you need to do is change the precision and default data directory.
mcduff
Message 12 of 16
(2,278 Views)
I noticed this issue when I was doing some testing earlier. I think I'm giving one more digit of precision than is necessary in the "number to fractional string" and then I'm likely experiencing a rounding error due to that.
Your solution is very clean. I've got some work to do and lots to learn... thank you for your guidance, I really appreciate it.
Message 13 of 16
(2,260 Views)
Look at the Help for Ramp.
You need to set the "exclude end?" to True. Then it should be okay.
Good luck.
Cheers,
mcduff
Message 14 of 16
(2,255 Views)
That's great... I put in a some logic to counter that issue and I got most of the way there, but setting that to true allowed me to remove all of that and it works correctly now.
Message 15 of 16
(2,250 Views)
I glad it works for you.
I gave you that last example as it may be easier to modify it in the future.
Because it uses a fixed string array (the 2d array on the shift register) you can do the following:
  1. Convert numbers into strings one-by-one. Why would you want to do this? You can use the # in your format specifier to delete trailing 0's. So instead of saving 0.10000, you save 0.1. This makes your end file smaller.
  2. You can start to handle cases if you have an unequal number of points. After a write to the file, set all the elements of the fixed string array to an empty string. This way when you write the CSV you don't have a bunch of extra 0's.
Think a bit about the case where you might need to modify in the future.
mcduff
Message 16 of 16
(2,244 Views)
