Reducing ROI of an image!!!!! Assistance Required
Hello folks,
i am back with  a doubt.
i am comparing two images for an image processing application, i have also attached the vi that i have made.
The issue is that i want to reduce the ROI of  both the images so that my pattern match can  be more specific..
As usual i have no clue as to achieve it . i shall be grateful if i can get some help
JALASHWA
(2,454 Views)
Hi Jalashwa,
Good day to you. You can start off by looking at the example VI. There is an example for pattern matching called Pattern Matching Example.vi. Use the example finder to look for it. In the example you can see that the property node is used to set the ROI of the image. Probably you can modify this VI to make it simpler for your application.
Alan
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(2,423 Views)
two common ways or analyzing images on smaller ROI subsets is to do an extract image (extracks smaller portion of image into new image space) or to creat a mask and perform your analysis within a masked region.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,411 Views)
