Reduction of Multiple Subsystem
Dear all,
I would like to ask that if I have the diagram below, could you give me or advice me to use Control Design for got the answer of T(s)? which T(s) = C(s)/R(s). Thanks! if can could you show me in 2 ways, Control Design, and also in Simulation.
(2,547 Views)
Hi Kaka2013 ,
If I am understanding correctly you are looking for a way to use the LabVIEW CD&Sim module to represent your Transfer function. If you haven't used the CD&Sim module so far I would first recommend you to walk through some of the tutorials that we have online.
Now particularly for your case I think you might be interested on the Simulation loop and the use of Transfer Functions on them, with the aid of the Control Design and Simulation Palette functions you should be capable to recreate that function on you LabVIEW project. I would recommend as well to start from the examples that ship already with the CD&Sim module there are multiple scenarios of base code that you can use for your development.
Please let me know if you have additional questions about this, also if you have any punctual questions of the CD&Sim funcitons we can all try to help you out better with this project
Sil.VI
(2,478 Views)
Dear s.jimenez
Really Thanks, for your reply, actually i can use it, but sometime I feel it not correct, maybe i got any mistake. so please could you check this pic? the formula below is the answer of the reduction, thanks. so if can could u create this model?
(2,470 Views)
