Reed Solomon Symbol Encoder (Decimal to Binary Converter)
One more thing If I want to convert boolean array back to decimal in the attached VI? Can any body guide me how to do it?
Message 11 of 21
(2,159 Views)
Boolean Array To Number.  It is right next the the Number To Boolean Array and in the same palette as the Boolean To (0,1).
Message 12 of 21
(2,146 Views)
I already did this myself but it gives only one decimal number in the output. But I want to get all the decimal numbers one after the other. Since there are more than one decimal no.s in the input of number to boolean part.
Message 13 of 21
(2,140 Views)
Looking at the code again...What's wrong with the Reed Solomon Encoder Output?  Isn't that data what you are looking for?
Message 14 of 21
(2,137 Views)
There is nothing wrong in the above VI. It is correct, but I want to make some modifications in it.
I want to convert boolean array back to number and want to get same result as i am getting at the "Reed Solomon Encoder Output" in the above attached VI.
Message 15 of 21
(2,133 Views)
In that case, you will need to use Reshape Array to turn the Boolean Array into a 2D array of Booleans.  The number of columns will be 32 and you will need to calculate the number of rows.  Then use the Boolean Array To Number (may need to be in a FOR loop).
Message 16 of 21
(2,126 Views)
I tried but it is not working, probably i am making some mistake. Can you plz guide me what is the mistake? (see attached screen shot)rs .jpg
Message 17 of 21
(2,122 Views)
You need to tell the Reshape Array the dimension sizes...
Message 18 of 21
(2,110 Views)
Still not working. I am going to attach my file below. Please look and guide me.
Message 19 of 21
(2,101 Views)
Where in my example did I use the Remainder output of the Quotient & Remainder.  Look closely at the code I gave you and the code you wrote.  And think about what you are trying to do and what each function does.
Message 20 of 21
(2,099 Views)
