Reed Solomon property settings not producing expected results
I am trying to perform a Reed Solomon encoding of RS(25,13) with 5-bit symbols. No matter what values in put in the RS Primitive Poly array the MT Reed Solomon Symbol Encode.vi stops producing the output symbols unless I leave the array empty??
I am trying to encode the following
Input  Message 0xA3142BABCFB63F90 + 1 unencrytped bit (0) = 0x462857579F6C7F20
which should be 0x2E0DCF3467DA1B2 after the RS encoding.
Primitive Polynomial  is g(X) = X^5 + X^2 + 1
Any suggestions?
Message 1 of 1
(2,348 Views)
